Hi Guys,
Im after some advise diagnosing a possible faulty graphics card.
I have an AMD Radeon RX480, never been overlocked or tinkered with appears to be crashing.
Most of the time the screen will go black and PC is unresponsive, occasionally it will hang and the sound will stutter repeating the last sound being played from the speaker.
Event viewer is empty right up to the event (only logging the fact the PC rebooted or was reset).
I did a Windows 10 "Reset" a few days back, installed a clean stable driver and no difference.
I have two monitors connected over Display port, have tried going down to a single monitor on a different port but no difference.
Playing ANY game will crash the PC. Running a graphics card Benchmark will crash the PC.
I've ran a memory test and CPU stress test and both come back fine, but when ever the graphics card is given any load it crashes.
WhattMan is showing temperature fluctuating between 50-80 degrees C.
Ive checked the card is seated correctly, the supply cables are connected correctly but am now running out of ideas, does anyone have any suggestions? Graphics card is less than 3 years old.
