- 31 Aug 2011
Recently i just bought a new Motherboard,
http://www.overclockers.co.uk/showproduct.php?prodid=MB-428-AS&groupid=701&catid=5&subcat=
a core i7 1366.
also a GTX 580 http://www.overclockers.co.uk/showproduct.php?prodid=GX-020-PN
and 6gb of ram.
the power supply im using is a Arctic Power 700w, i used this to power my last card (GTX 260) for 2 years.
When i built my machine i realised my psu didnt have an 8 pin for my pci-express card so i bought a 6 pin to 8 pin converter. when i turn my pc on all i get is a blank screen with a flashing monitor power button. (When i put my gtx 260 back into the machine it works fine, the new cpu and ram work like a charm) but when i put the 580 in, the power button just flashes on the monitor and there is no display "at all" I have tried using another monitor but also no display. i have tried using the other dvi socket but still no display. i have also tried putting the card into my dads computer and the same problem persists, all though there was a slight difference. when i put it in my dads machine the 580's fan powered on REALLY LOUD, but it only did that once. the 580 always powers on normally but there is just no display on the screen at all. I am using my old gtx 260 for now with all of my other new componants (i7, new ram and motherboard) what do you think? faulty gtx 580?
a core i7 1366.
and 6gb of ram.
