Fax modem problem
3 Apr 2009
Preston UK
I am having problems with my external modem:
With one customer I can’t send faxes to them or receive faxes from them.
With another customer I can fax them but can not receive faxes from them.
My modem seems to be working correctly because I don’t have problems with others customers or suppliers but the two customers I’m having problems with are adamant the problem is not caused by them.
I don’t know what to do at this stage new modem?
My modem is:
http://htfelectronic.en.made-in-chi...kb/China-56k-External-Fax-Modem-HT-EU09-.html
Thanks in advance for any help
Is this modem connected to a BT line or a PBX system?
Though on the face of it if you can fax everyone bar those two customers then it's usually they've ballsed it up at their end. Wrong number, no 9 prefix or something. Or sometimes the fax machine is off/unplugged.
Well first place to start is plug a phone into the line or use hyperterminal with the volume up and ring the number and see if a fax answers. That will confirm basic connectivity and rule out line issues (which are doubtful anyway)
Ok I have plug a phone in the fax dialled the fax line in question & get a fax answering.
Ok so we know the line works at both ends. We know your modem works because it can fax to everyone else. Do you have another fax machine you could connect to it to send a fax? Preferably not software driven.
Hi I just sent a fax to them using our old fax machine they received it no problem at all.
Then the issue lies with your modem/fax driver most likely. It's possible they have an older fax machine that can't handle super G3 speeds or whatever and your fax driver isn't negotiating transmission speed with it. I'm not sure how you'd get around this unless you can manually adjust the modem sync down and test it that way.
