Try doing a fresh install and then installing the patches straight afterwards. Remember to download the UK versions of the patches and not the US ones.
i had the same kind of problem, if u have any kind of codec pack e.g. ace mega codec pack that could be causing the problem.
try disabling or uninstaling a codec pack if you have one.
if not have a look through the readme it has a few known issues and fixes.
well thats **** are there any really good codec packs out there that done have issues? or is it the codecs themselves that the game has a problem with?
