- 11 Mar 2005
Evening all.
I'm wondering if anybody has any advice regarding roofline products... specifically dry verge and the like.
I have clad an old battered brick outhouse in feather edge, as below..
My issue is that - without ripping all the tiles off and realigning them - I can't actually ensure an overhang. If anything - the feather edge sticks out by about 10mm. I had contemplated using some lead free flashing tape as a short term (5yrs max) fix - as I'm hoping to knock the whole thing down and re-build a garage at some point - but I'm now wondering if i could use some dry verge caps? My question being are they flexible enough to fit snugly over the feather edge - or would I be better making a batten just under the roofline, and allowing the dry verge to attach to that?
Re-doing the whole roof isn't really an option at the moment, combination of dosh, and too many other projects!
Here's the reason this all became necessary...
As I say - this is only really to last for 5 years or so - as I've got a timber framed garden room planned for the space... but any help gratefully received!
Cheers,
Cheers,
