No it wont work as you will only have 300mm or 12" in the ground using 8 foot posts
With 6 foot panels and 12" gravel boards you will need 9 foot posts,( you need a minimum of 18" in the ground, but 24" is better especially if the ground is soft)
Dry concrete, exactly as i said, in a wheel barrow put 6 shovels of ballast, 1 shovel of cement, mix it with a shovel.
Put post into the hole ensuring its at the right height, get a helper to hold it plumb (vertical on front and side of post) using a spirit level.
Put in 2 shovels of concrete mix ensuring all 4 sides have equal amounts.
Pack the mix down with a piece of wood eg. bit of 50mm x 75mm or even an old spirit level, when i say pack it down i mean pack it down hard lol. Do all 4 sides in rotation.
Add another 2 shovels and pack as above.
When you get to ground level you will be surprised just how firm the post is in the ground, it wont move lol.
There is enough moisture in the ballast to cure the cement as it is, but its better to use roughly 1/2 to 1 watering can of water on each hole at the end of the day.
Btw, you can put the concrete in wet if you want, but imo its much easier if its dry
If it not windy you can add the panels as you go, if its windy just drop them in the next day, its easy as they slide doen the slot in the posts, (also im am 6 foot 4 lol)
As i said before i install fencing regulary and this is how we do it.
Personally ordainary cement is fine, it will be hard the next morning, also if you notice towards the end of the day you made a mistake, there is still some time to fix it if you used normal cement
whereas postcrete (rip off) or rapid cement will be a much bigger job to fix any mistakes
