- 28 Oct 2006
Hi,
Few questions before I order parts.
1. I'm going for Conroe E6600 + Abit AW9-D + Zalman CNPS9500AT.
The CNPS9500 Manual says to spread thermal paste across the top of the chip. Is this correct or will a blob do and let the heat spread it natrually?
2. I'm going for a 19" LCD Widescreen + 3D Connect X1900XT 512mb card. 3D Connect say the card comes with a DVI-I Connector.
However the 19" Samsung and Viewsonic screens state they have a DVI-D input. So does the DVI-I cable match the DVI-D socket??
3. The Connect 3d x1900 XT 512mb card website states:
"16:9 aspect ratio monitors are supported on 1920x1080 and 848x480 on Windows® XP"
http://www.connect3d.com/products/pcie_x1900xt.htm
Most 16:9 LCD Monitors optimal resolutions are well below 1920x1090. Usually around 1280 x 1024.
How does this work? I get the impression the card will NOT support 16:9 ratio at 1280x1024. But only at 1920x1090. Which is very demanding on performance.
4. For Crossfire, do I NEED the master card for 1900xt? Or can I use x2 3d connect x1900xt 512mbs? On the Abit AW9D manual it shows 2 ATI cards, one with a DMS59 Connector and 1 without. So thats confusing.
5. Is there any cables or special connectors that arent included in these components which I would need to buy extra for them to work?
6. I'm also buying Corsair XMS2 6400 TwinX C5 2x1GB RAM. On the Abit AW9-D Motherboard for dual channel setup do I install them in Dimm1+Dimm2, or Dimm1+Dimm3. On the old MSI Neo2Plat the manual would state Dimm1+Dimm3 but in actual fact you would have to put them in 1+2 for it to go dual channel.
I appreciate any help.
Thanks
Thanks
