Alright folks,
So I'm having a few problems since my recent upgrade. I've spent the past full day trying to resolve them to no avail. I may re-format and start again.
I've gone for the following -
Intel i7 4790k
Asus Maximus VII
Corsair Pro Vengeance 2400mhz
Asus Phoebus Sound card
from
Intel i7 2700k
Asus P8Z68 V Pro
Corsair Vengeance 1600mhz
Soundblaster Z Sound card
Firstly, the 4790k is HOT. I know they are supposed to be quite hot, but on Prime95 I'm getting just under 96c... It's hooked onto a H100i, and all is mounted properly and thermal paste is used correctly. Looking at the web apparently there's been a bad batch of 4790k's? But then again a lot of other people say to ignore Prime95 because Haswell hates it.
Next, my desktop has gone choppy since the upgrade. I use a 144hz monitor and it feels like 60hz sometimes, when I drag windows around it can be really juddery. I use Dual link DVI, and have SLI 680's. I never had a choppy desktop before because I used to play around with my desktop all the time and love how smooth it was. Now that's gone it's really strange and I really can't put my finger on it. Although when I first enabled SLI my PC blue screened. When it rebooted and I enabled it again it worked...
Finally, my PC time is wrong. Always. The BIOS time is incorrect, and it's a brand new motherboard so I know it's not the battery. Every time I log into Windows I have to re-set the internet time. I never had to do this before, it worked all the time!
I think that's it. I really appreciate any help with it guys
Intel i7 4790k
Asus Maximus VII
from
Intel i7 2700k
Asus P8Z68 V Pro
