Hi guys,
I was wondering if any of you had come across this fault before.
Basically, when I click on file explorer or try to open any folder (or even if I was trying to save an image from a website), the window opens but it takes about 30-40 seconds to do anything. If I try to click in the window it says not responding..
A weird thing is that I can open the first window, knowing that I cant use it..but then open a separate folder to then navigate my way into where I wanted to go.
I just don't get it!
I got the trial version of AVG PC TUNE UP and its telling me there are over 600 issues to be fixed....is this true or are AVG just as bad for selling you their product in a scare tactic way?
Any help would be awesome, ive tried the microsoft Q&A but cant find anything on the issue.
Thanks
Thanks
