Filezilla help
26 Oct 2008
Hey there,
My other half and myself use Filezilla for work, trouble is the NVQ company we do work for has to send someone to wherever we are currently working away to setup Filezilla for her with their company login information. Now the problem is she did not write the login information down when they did it for her and as she is unable to get someone until Tuesday to give me the information to do this for her is there any way to retrieve this within Filezilla?
We have a new domain that I will setup for her on her client and I am basically going to add two forms of login she can select from to connect to either the company or our company FTP (Which I assume you can do in Filezilla?).
At present if she selects reconnect to server it will login to that NVQ company FTP and I am trying to save that information but I am unable to see a way to record it via the current information for login that is already there before I add our new domain as I don't want to lose her FTP login from the company.
Windows Vista/7: C:\Users\Reebro's Other Half\AppData\Roaming\FileZilla
Windows XP: C:\Docs and Settings\Reebro's Other Half\Application Data\FileZilla*
[don't have XP to double check that path, but I reasonably expect it to be there]
Go to that folder I detailed above and take a look at the XML files in there. It will either be in in recentservers.xml or sitemanager.xml. Any text editor should be able to open the files.
Ah looks like that will work, I shall inform the company she sends the work to that I have done this also as she forgot to write it down, cheers you two.
