Final build - Thoughts?
28 Feb 2004
North East, UK
Hi,
After weeks of deliberating I think I've decided on the parts for my new build. Will the PSU be okay with this system and will the CPU cooler fit okay inside this case? Any advice would be great. Will mainly use it for gaming! :)
Danke, is that a decent brand?
Sure, I don't know what the actual IC's used are (maybe ask 8 Pack?), but I have some Team xtreme 2400 RAM here and I can get it to work at 2666Mhz with similar timings to its 2400Mhz XMP profile, or use the 2400Mhz XMP profile and tighten some of the timings up nicely.
If you are getting low profile RAM, you'll be fine. I can get the Patriot RAM undermine and that give 0.5cm clearance form the K2 cooler. RAM like the Corsair Vengeance will not fit.
Thanks I was tempted by the red corsair vengeance to go with the red motherboard. Will the other coolers fit?
Finally ordered my build, went for this lot in the end :D
Got a Logitech G400 brand new for £14, and ordered a Sidewinder X4 keyboard. The board comes with the free cooler, as I don't intend to OC much, can't wait!
