- 30 Mar 2007
Hi all. I hope you guys can give me some advice. My machine is beginning to look a little long in the tooth now and I would like to upgrade it to give performance a boost. Haven't been on the boards for quite a while and in my absence it seems that Intel is now the new AMD! Totally confused over their processor range hence seeking advice if this the way to go over AMD.
The pc is mostly used for general web surfing etc including running a lot of web based Java apps. I occasionaly play online games such as COD2 and would like to give COD4 a spin.
My budget is £200- £300 and as a starter I am thinking of new mobo, processor and memory if this would give a decent performance boost over my current setup. Poss a new graphics card as well.. possibly 8800GT? The only real requirement is to have a reasonable upgrade path for later in the year, ie maybe a better processor. Am willing to do some basic overclocking to get better performance. A tall order I suspect!
My current spec is as follows:
AMD 3700+ San Diago core - overclocked
ASUS ASN 8 SLI SE motherboard
1GB Geil value ram
XFX 7800 GT graphics card
Pioneer DVD
Lian Li AO5B case
Tagan PSU (500w - I think)
Samsung 500gb SATA drive
Running Windows XP
Thanks!
1GB Geil value ram
Pioneer DVD
Lian Li AO5B case
Running Windows XP
Thanks!
