Trying to diagnose problems with "out of range" and "no signal" errors on display. This is the last effort prior to sending mobo and cpu back for possible replacement which could take up to 28 days. Any thoughts into diagnosing would help. System has been built for over a year prior without issue.
GPU has been in PCIE slot 1 and I have been using #1 GPU display port out all this time. CPU has been overclocked from 4 to 4.6 all this time. GPU has not been overclocked at all.
1. tried changing resolution/gsync - no change
2. tried changing cable - no change
3. tried changing screens (with same model Asus PG279q) - no change
4. tried changing to PCIE slot # 2 - error went away but came back shortly after
5. moved to PCIE slot#3 - error went away but came back shortly after
6. moved GPU back to slot #1 - used #2 display port out on GPU - runs fine
7. tried different GPU (GTX 970 G1) - issue still there
8. uninstalled reinstalled drivers - no change
9. updated mobo bios - no change
10. tried safe mode in windows - no change
11. tried safe mode on GPU - no change
I have stress tested CPU and GPU to see if there are any errors - none. Everything else works without issue (although after bios update I can't seem to get my ram back up to 3733mhz).
Any ideas ??
System:
Case: Phanteks Enthoo Primo
Mobo: Asus Maximus viii Extreme
CPU: i7 6700k @4.6
HDD: 3 X Samsung 1TB SSD 850 PRO SATA 6Gbps
Ram: 16g DDR4 Extreme Group 3733Mhz
CPU Cooler: Corsair Hydro Series H110i GTX
GPU: ROG GTX 980ti Matrix
Sound: Asus Essence 7:1
Optical: Pioneer BDRW
PSU: Corsair HX1200i 1200W '80 Plus Platinum
OS: Win10 pro x64
Any ideas ??
System:
CPU: i7 6700k @4.6
OS: Win10 pro x64
