Finalised system: Pls Comment
25 Oct 2009
Here is the final decision that I have come down on. Can anyone comment and point out any problems pls. I have taken everyone's advice into consideration, and this is what i gotz:
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz + Coolit Systems Domino A.L.C Watercooling System Bundle
Gigabyte GA-EX58-UD5 Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
Asus VH222H 22" Widescreen LCD Monitor
Corsair TX 950W ATX SLI Compliant Power Supply (CMPSU-950TXUK)
Coolermaster HAF 932 Case - Black
OcUK ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card + Colin McRae Dirt 2 Full Game + Ruby Doll * 2
Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel (TR3X6G1600C9)
Microsoft Windows 7 Professional 64-Bit - OEM (FQC-00765) £107.99
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM (ST3500418AS)
LG GH22NS50 22x DVD±RW SATA ReWriter (Black) - Retail
The coolit domino is crap, you don't want that. Otherwise nothing too bad. PSU is overspecified, but then that's a good component to overspec.
Didn't think 7 professional offered anything significant over home premium but I daresay you've checked this.
Agree with Jon, persnally Id get a 750HX (still more than enough) rather than 950TX, and yeah unless you need the specific features HP is enough for 99% of people
What is the PC going to be used for? I assume gaming, in which case as JonJ said Home premium will be fine. Also many peope's favourite HDD's are WD Caviar Black or Samsung F3, so you may wish to consider those. You would probably be fine with a 750W PSU, but go for 850W if you want, 950 is a bit overkill.
OK, Will do, I have heard about the samsung f3 3 times today, and had a look, but cant find it. I will go for an 850, because later on I intend to make huge upgrades, ie an extra 5870, another 6 Gb RAM.
The Domino is part of a package deal with the i7 though, so....but if there is that much difference.....
I do intend to use it for gaming on high res, and 3D animation etc.
Probably yes, but are you likely to want 3 in xfire? Scaling isn't brilliant, you'd be better off when the time comes selling the 5770s and getting a 5970 or something.
What others have said is good advice - change to a H50. :)
I did go for a 1TB F3, and the other thing bout this sys is that I can get a little money back from all of the copies of dirt 2....
how much do you reckon i can get/each copy?
with all of the modifications I made there are currently 3 or 4
Well you dont get the cd only a code to download as far as i know... So with that in mind i would imagine not a lot as a lot of people will prefer the disc.
