Finalizing my build - Need some minor Help
12 Mar 2011
Hello Everyone,
After some tinkering i came up with the build below:
Intel Core i5-2500K 3.30GHz
Asus GeForce GTX 460 1024MB
Asus P8P67-M PRO Intel P67 microATX B3 REVISION
Corsair Dominator 4GB (2x2GB) DDR3
OCZ StealthXStream 2 500W Power Supply
I'll buy the case locally and I'll be keeping my old 1TB HDD
Is it good to run most games that will come out this year? This is the second time i building a PC so I'm really not an expert. Any tips or suggestions are welcome :)
I'm mostly worried about the 500w PSU that might be a little low, Also my current rig is:
Core2Quad Q6600
6gb ram
9800gt
and thanks for the replies
im not an expert on these things, but i would change the RAM to the OCZ platinum 4GB kit. this runs at lower voltages, has the same timings and costs WAY less.
i really cant see why the other stuff is so expensive, but there must be some reason, so if someone could say why i would love to hear it. it might be something to do with how much you can overclock it, or how much it affects other overclocks
