And here are the TriumphTune specifications (bit optimistic sometimes) for various states of tune. Note - these assume your engine is in 100% health and generating the maximum ~70BHP it should have had when leaving the factory:
Stage 1: 80 Bhp
- K&N air filters
- 4-2-1 Tubular exhaust system with straight through silencers (don't bother having a radio after getting these!)
- Richer Carb needles
Stage 2: 90 Bhp
- K&N air filters
- 4-2-1 Exhaust
- Richer still carb needles
- Electronic Ignition
- Decent plugs
- Decent leads
- Oil cooler
- Wide radiator
- Mild head flow work
Stage 3: 110 Bhp
- All the above
- Lightened flywheel (just makes it rev up faster)
- Fully Balanced internals
- Uprated con rod bolts with polished rods
- Triumph Tune Fast road 83 camshaft
- Compression > 9.75/1
- Triumph Tune stainless steel valves, bigger 1.475" inlets with standard size exhaust valves
- Bronze valve guides
- Flowed head
- Slightly stiffer valve springs
- Three angle valve seats
Stage 4: 120 Bhp+
- All the above
- Nitrided crankshaft (wears less)
- Performance bearings
- Fast road 89 camshaft
- Vernier duplex timing chain & sprockets
- Twin Weber 40DCOE carburettors
- Exhaust wrap
- ARP flywheel bolts
- Drilled crank & flywheel for additional fasteners
- Lightened & nitrided cam followers
- Chrome moly push rods
- Roller rockers
- Bigger exhaust valves
