finally got a vga cable
18 Aug 2004
midlands
....but
how do i connect it, as the two connectors are the same, i have no instructions because i got it off ebay
thanks in advance
nickels
wyrdo said:
You'll need to get yourself a gender changer for the end connecting to your monitor cable. They're only a couple of quid and a quick search on Google will help as the place I had put appears to be a competitor as it got starred out :confused:
Edit: This sorta thing http://www.homestead.co.uk/productcategorydetail.aspx?CategoryID=51285&onspecialoffer=False
:( why lol, why couldnt they make it go to the cable straight away, and where i connect the sound, i have surroundsoud for pc but dont know where to connect
he is in the same boat as me, my monitor has a fixed cable so i had to buy a gender changer, if u get the official microsoft one u get the adapter with it, its just the 3rd party ones you don't.
My old monitor for example didn't have a fixed cable and i could have plugged it straight in the back of it.
The sound side i had too buy a little adapter that split the 2 phono connectors into a normal 3.5 stereo adapter that you would use in your soundcard for example, luckily my woofer had a spare input, the other way is to get a optical cable if u got it on the pc etc, to give true 5.1 surround.
I haven't met an LCD with a captive VGA cable. That's why they don't make it with a female end.
where can i get one of those sound adapter things? or is it a competitor again?
i just went too a small tv shop for the audio part it cost £2, place where u can buy accesories ie cables etc, i imagine anywhere that sells audio stuff will have them too.
either of those will do it i got the top one.
