Ive currently got a 512 HDD which I've had a year or so,with 200mb left to play with,but the itch to get a nice shiny new SSD is here.
Now my problem arises when I read the forums about Raid,partitions updating the FireWire from a disk setting the bios to whatever needs doing.
So what I was thinking is I'd like a match in storage 512 in a single SSD and running it as the only drive in my PC,maybe down the road I'll add my old HDD back once I get the confidence to do so.
My board ATM is an Crosshair IV Extreme Amd motherboard do I just unplug my old HDD and reconnect it or do I use the sata 3 port over the 2?
Do I install windows straight away or enter the bios if so what changes do I need to see?
Last but not least could someone recommend a SSD my budget is about £550-£600 at a push bearing in mind I only want one I know two smaller ones to make same storage might be cheaper.
