Hi all, not posted here in a while and a little out the loop.
I have a SFF PC I built a few years back, specs as follows
I5 11400
16gb ddr4
1tb ssd
8gb rx480
I don't plan on upgrading other components, so would like a gpu to compliment my current spec and limit a bottleneck on either side.
Usage, it's connected to a 4k display but don't mind limiting to 1080p, 4k would he nice if my CPU and RAM don't hold things up
light gaming, my son uses it mostly, would like to run things like cyberpunk at 4k if poss without much trouble, not a deal breaker, would also like to be able to run minecraft with textures and Ray tracing
Budget 500 ish
Many thanks
I5 11400
16gb ddr4
1tb ssd
8gb rx480
Budget 500 ish
Many thanks
get a used 3070 for basically half that for almost identical performance
