- 14 Feb 2004
- Peoples Republic of Histonia, Cambridge
You can get boxes for joining armored electrical cable underground. You might be able to find something that would accept pond/garden hose diameter, but it's gong to be expensive.
Failing that, I would just use a high quality sealable tupperware box and carefully cut three holes in it using a hole saw. It won't be water tight, but it should keep it clean'ish. You might even be able to find some grommets if you have decent local hardware shop.
I want to be able to access it instantly
