Finding out water rates?
16 Nov 2002
The Moon
In process of buying a house and current vendor says he doesnt know what the water rates are as it was his dads house.
Does anyone know of any way I can find this info out? I believe its based on what the houses rateable value is but I've tried doing some google'ing and can't find anywhere online that tells me this info!
Is it something my solicitor can find out for me?
I didn't think the water company would tell me the info I needed but just had a quick chat with them on webchat and they did. Splendid!
All the websites have unmetered charge guides somewhere.
As Haggisman says assess how much difference there would be getting a meter installed.
if you can't get a meter installed there's another option if you think your being overcharged but I can't remember what it is.
googling will serve you well "reassessed bill" or something like that
EDIT
Your water company can refuse to install a water meter at your property if it is not practical or is too expensive for it to fit one.
If you cannot have a water meter installed, your water company should offer you an assessed charge. This is an alternative to your rateable value charge.
You will not be offered an assessed charge unless you apply for a meter.
Setting assessed charges
Assessed charges are generally based on one of the following:
the number of bedrooms in your property
the type of property you live in
the number of people who live in your property
the average metered bill in the water company’s area
