finding out when a document was created
10 Aug 2003
London
Hi there,
Is there any programs or ways that can you can tell when a document was created. Example i have a pdf file that was sent, however the creation date is not included in the properties section when i open up with adobe acrobat?
I realise that you can edit/change the dates you created a file, either by changing the properties or just adjusting the system time on your machine when you create the file.
Thanks in advance
In explorer, right click on the file in question and go to the details tab.
thanks, is there any other way?
I have 7 documents where the date created, modified and accessed for each document is all set to 02/10/2014 04:24:32 if i look it up the way you said. Could that be the date & time the email these documents attached to was sent out?
