finding the 50 a bit too "zoomy"
The corners are a bit soft, but they are on the canon as well. Bokeh is much better on the sigma as well. If you want to see really dodgy edges just stick it on a full frame :D
Jennie by jj_glos, on Flickr
Any chance on 100% crop on the eye? that looks cracking at F1.4 compared to my Nikon F1.4! I cant seem to get it sharp at focus point!
A very helpful bunch of responses, thanks!
I'm on a tight budget and still saving hard for a 70-200L to replace my 55-250.
I'm going to keep an eye on TP and eBay for a good example of a used 35mm!
I'll dig out the original.
Assume that picture is of a crop sensor lens on a FF, as it's vignetting...
Yeah the Sigma is a crop only lens, hence why many are eagerly awaiting the new 35 f1.4 from them.
