Have you bought the things you listed or are those just things you have decided to get?
If you have not yet bought anything, I'd strongly suggest you have a look at
this motherboard.
As for the rest, you will need RAM, graphics card, CPU cooler, case, power supply, DVD drive (or blu-ray), hard disk (or SSD), operating system. If you are starting from scratch entirely then you will also need a monitor, keyboard, mouse and speakers (or headphones/headset). Also, you may want things like a discrete sound card, a secondary storage hard disk, desktop microphone, webcam, joystick, steering wheel etc. etc.
We will be happy to specify the whole lot for you, you just need to tell us what you will be needing, what you plan to use it for and what your budget is.
