Firecuda 530 flux or conformal coating? Weird residue
27 Oct 2009
West Sussex
Hi all,
I've never come across this before on other NVMEs, and its the first Firecuda 530 drive Ive got here.
Searching on google didnt bring up good enough images to compare, so I hope someone with a drive can comment.
I seem to have some flux or conformal coating locally on the drive as per images - not even quite sure if that is actually what I think it is.
Its a brand new drive and I haven't plugged it in yet to check if all works ok.
Would welcome input if you came across this before.
Thanks
It seems very localised, and solder still present :)
The drive seems to be absolutely fine, but it was an open box item so I didnt know if this wasn't the reason for the return.
I tried - didn't really find anything from the same angle or close enough to see.
Drive tested all ok, IOPS are through the roof on this thing so I'm definitely keeping it.
