Firefox Problem?
15 Feb 2008
Hi,
Have been using firefox for many years but over the past week firefox keeps freezing "not responding". Have done a clean install of firefox and installed the latest nightly beta and still have the same problem.
No Add-ons installed
Latest amd drivers.
Hardware acceleration & Flash are disabled and the same problem.
Any other ideas?
Not sure why but the Firefox betas have been unstable for me for a while now. Often it will fail to respond and I can sometimes get it to still work by closing down the plugin container. I did find that it was Adobe Flash often failing to respond once the plugin container was ended as a task.
I did move over to Chrome, works better across my devices, but I do like FF on my main machine and so I have come away from the beta channel with a hope of improving the stability.
I understand that Flash is frown upon by many but until I can browse and use websites as ~I would like or need to then I have little choice to use it.
thanks, have removed firefox including all profiles from my system but my system now freezes when opening files, programmes ect.
Going to install windows 7 to another SSD to see if I have the same problem if so time to check RAM ect. My only hardware change is graphics card.
