Firepower for Combat Flight Simulator 3
Caporegime
25 Nov 2004
On the road....
I have just recieved a copy of Firepower for Combat Flight Sim 3 (CFS3)
http://www.airwarfare.com/Sims/CFS3/firepower.htm
Trouble is, most of the extra Aircraft included in this package simply don't show up in my simulator.
All of the files have installed correctly, from what I can see, but none only a few are actually available to use in the sim.
Some added effects work (Nuke bombs eg) but not the aircraft.
I've been playing CFS 3 since launch, and have never had issues before, I've even removed my much modified install (in case any of my other add-ons were conflicting) but get the same result with a Vanilla install. :(
Any flight simmers out there who can help me?
Thanks in advance.
Edit:
Update.
After a good long trawl through the Firepower / Shockwave Forums, it seems my using the dreaded no-CD patch could be the issue.
Fair enough, I've un-installed (again!), re-installed a clean, updated CFS3 install (fully manually deleted the old CFS3 folder & cleaned the registry)
And, guess what?
Yup! - I still get no heavies on my Aircraft list!
cry
Looks like my CFS3 revival is going to be very short lived.
What really annoys me is if I download a Freeware B17 4 engine plane that I've found, it works fine!
Any avid CFS3 simmers out there in OCUK land? Help!
hello mate
not sure if this will help you, but when i installed firepower i had the same issue, fancy new bombs but no new aircraft. I right clicked the .exe file and run it in compatibility mode for windows 98, the game ran fine with all new aircraft in, then strangely enough, after that, even when i didnt run it in compatibility mode it all worked fine. Flying the jets and B17s + 24s on full simulation is great fun with a force feedback stick!
Hope this works, and enjoy!
hello mate
Thank you for the reply, and one that I had not (yet) tried.
I've re-installed, un-installed, added planes then removed them manually all to no avail (but,choosing nuclear armed Spitfires for quick combat wasn't an issue!:confused:)
Well, I just read this reply & subsequently tried your suggestion and I'm delighted to say YEEEEES!! :cool: it worked! :D
Absolutely delighted! - Thank you for the tip - never known Windows combatibility to be an issue with CFS3, which surprises me, given that I'm a long standing member & ex-moderator of a Flight simulaton forum - where I'd drawn a blank also!! and my knowledge of the FS / CFS series of games was,so I thought, very comprehensive! :o
Like you, having once ran the .exe in compatibility mode, I've subsequently re-booted the rig and tried the sim again without first running the compatibility wizard thingy and its now working quite happily! - No bother, I'm just pleased it works! :o
Old Dog , new tricks is the moral of my woe I suppose! :D
Thanks very much again mate! :)
For the confused many, wondering what the hell were on about!! :D
