Firestrike Extreme Bench.
@Kaapstad Thankyou, this is the last one. I'm done now, promise :D
5950X PBO
6900 XT 2750/2150Mhz
21.2.1
SCORE 29502 with AMD Radeon RX 6900 XT(1x) and AMD Ryzen 9 5950X
Graphics Score
31483
Physics Score
40589
Combined Score
15680
Settings used :
CPU @ 4.55GHZ All Core 5950X PBO On
8Pack 4 x 3200 Ram @ 3800 - 16-16-16-36 - 1.475v
GPU
Min Mhz : 2716
Max Mhz : 2816
mV : 1170
Memory - Fast Timings - 2150MHZ
GPU Watt Set to 325 using MPT and Power Limit set to +15%
Fans on Auto. Think that's everything.
:D
5950X PBO
21.2.1
Graphics Score
31483
Physics Score
40589
Combined Score
15680
Settings used :
GPU
Min Mhz : 2716
Max Mhz : 2717
:D
That is truly impressive, id love to see a timespy with that setting!
Your absolutely right there!!!!
When I get knocked off the top I will revisit it, don't want to peak too early :D
With Curve Optimizer you might be able to improve your score a little without going manual overclock.
But to breach 42000 points you'll need an all core clock of 4.7Ghz++.
Here is a quick custom run doing just the Physics test.
All I did was put the multiplier to 47, I have not even got my best memory sticks in the PC and not optimised either.
https://www.3dmark.com/3dm/58076996?
Shame I have not got a GPU fast enough to benefit.
I don't think my 5950x is up to it. I will try that tomorrow, did you just use with Auto Vcore of set something manually? I tried using CTR and it only recommended 4.525 at 1.25vcore.
I just leave the Vcore on auto, If I try to set it manually it won't run with clockspeeds above 4.6.
I have to run mine at 1.35v for 4.8ghz all core. 1.365 it crashes and 1.3375 not enough and crashes in Windows
Needs llc on high for the cpu also, or again unstable
My ambitions aren't quite as lofty as you top hitters but I'll humbly take my position back in the top 5. :D Not my best graphics score but got the new Phanteks Glacier One 360 cooler for the 5800X:
5800X PBO + 150 Mhz (water)
6900 XT 2705/2150Mhz
21.2.1
SCORE 26757 with AMD Radeon RX 6900 XT(1x) and AMD Ryzen 7 5800X
Graphics Score
29677
Physics Score
30682
Combined Score
13867
Edit: Tightened my RAM timings up a bit; from 18-22-22-41 to 18-19-19-39 which boosted the physics and combined score by 1.8% and overall score by 200 points. Updated the above metrics since they haven't been added to the scoreboard yet.
