Firestrike Extreme Bench.
http://www.3dmark.com/3dm/191102? Score: 3729
Graphics Score: 3968
Physics Score: 8090
Combined Score: 1651
680 Lightning @ 1346 Core, 7204 Memory - Air
i5 2500k @ 4.8Ghz - Air
Got another Lightning on the way tomorrow and hopefully that will clock better than this one and I will have the joy of SLI :D.
All scores updated, thankyou everyone for posting
Well done Nickolp1974 for going to no.1
Thx mate ;) still intrigued to know why i'm scoring higher than you considering your gpu is running faster.
Possible reasons?? My os install is only a few days old?? And maybe because i dont have an anti virus installed yet?? Dunno?
I have just had a look, your GFX score is a bit better and your Combined Score is a lot better (over 100 points). I think this Bench does not place so much emphasis on the Physics Score and so evens it up a bit when comparing Quad and Hex core CPUs.
Score 6292 with NVIDIA GeForce GTX 690 @1116/7200/1220 Air Cooled
Intel Core i7-3960X Extreme Edition Processor @4.9 Water Cooled
Graphics Score 6802
Physics Score 17567
Combined Score 2492
http://www.3dmark.com/fs/143619
Score 3613 with NVIDIA GeForce GTX 690 Single GPU (GTX 680 mode) @1116/7200/1220 Air Cooled
Graphics Score 3681
Physics Score 17557
Combined Score 1551
http://www.3dmark.com/fs/143711
Kaapstad, you have put that I am using VirtuMVP for my SLI score but I am not. Can you say what makes you believe that or is it just a mistake?
http://www.3dmark.com/fs/150705 Score: 5333
Graphics Score: 5907
Physics Score: 8567
Combined Score: 2325
680 Lightning SLI, 1202 Core, 7000 Memory - Air
It shows Generic VGA on your results. I would also do the same and just turn off your onboard gfx via the bios screen. Only takes a sec :)
I can see it isn't doing anything to your score but it does keep it consistant.
Hope that helps :)
I am sorry if I have made a mistake
Hope that helps :)
If you can do the above as gregster has sugested.
I have still included your score as the table says multi GPUs rather than 2 GPUs.
Hope that helps :)
My motherboard doesn't have any on board graphics, dunno why it says that heh. I'll check it out in a bit though.
The CPU does. I am sure it isn't at play at all but does make it easier for me and Kaap if it is disabled.
http://www.3dmark.com/fs/56056
That was your single card score in the 3DMark fire strike (normal) thread and it shows only the 680. Maybe going SLI has changed something on the mobo?
