Firestrike Extreme Bench.
Scoreboard updated.:)
How are your PSU's coping btw? They holding up fine?
They are both doing fine with only two cards on each one. I was putting 1.412v through all four cards last night with no problem at all.
My only problem is these IB-E CPUs could do with being a bit faster as mine is a serious bottleneck.:D
Kaap which AMD driver are you using for benching?
13.12
I think that 13.11 is supposed to be better though, I will have to give them a go at some point.
The problem with switching drivers is disabling ULPS in the registry, with 4 cards there is about 50 entries to change.:eek:
13.12
Yeah im on 13.12 but i saw some of your benches on a beta of 13.11. Just wondered if it was worth switching to eek out some more points.
Does disabling via AB not work?
This.
I don't really want to run AB as it could cause problems with GPU Tweak.
Does disabling ULPS in AB stay in effect even after AB is no longer running.
What I am asking is could I run AB, disable ULPS and then close AB and open GPU Tweak.
Yes it does. Use AB to disable ULPS, restart then use gpu tweak as normal.
