Firestrike Extreme Bench.
https://www.3dmark.com/3dm/21948304?
Sapphire RX VEGA 64 AIO @ 1777/1100
RYZEN 1700 @ 3.9/3066
Drivers 17.8.2
Could you post what you are using to cool your CPU please.:)
Scoreboard updated.:)
K - I'll update my various bench scores sometime soon when I have some time as whilst the GHz numbers were rubbish on the launch 17.8.1.beta6 drivers the scores obtained are good but it would be good to get the correct numbers shown.
Ryzen 1800x @4.075Ghz
Vega 64 @1812/1100Mhz
Crimson 17.8.2
11 520 with Generic VGA(1x) and AMD Ryzen 7 1800X
Graphics Score
12 522
Physics Score
21 581
Combined Score
5 011
https://www.3dmark.com/3dm/21938434
Vega 64 @1772/1100Mhz
Crimson 17.8.2
Improved my score a little, with lower set clocks/voltage in Wattman, which resulted in higher clock speeds seen during the bench.
SCORE11 624 with Generic VGA(1x) and AMD Ryzen 7 1800X
Graphics Score
12 807
Physics Score
21 559
Combined Score
4 877
https://www.3dmark.com/3dm/21988610
And this is my score with heavy undervolt (1000mV only! in state 6 and 7), 1680MHz stable GPU clock (1700+MHz with that low voltage wasn't stable), 1100MHz memory clock. Uses 100+W less than stock. Power limit on 0% since it's liquid Vega and increasing power limit does nothing at all in these settings.
https://www.3dmark.com/3dm/22003496
Could you confirm what you are using to cool your CPU please.
Ah, sorry, water cooling (AiO loop, Artic Liquid Freezer 240mm). Very very silent and more than enough for my needs. :) In general, the whole idea of my PC was to build powerful yet as silent as possible AMD based PC. And it worked out great!
Thanks.:)
