Firewire help
I believe you can buy a cable that is usb one end, and fire wire the other...depends what connection he needs I guess...
Or as BENdage said, you can get PCMCIA cards that have firewire connections on them.
Get the PCMCIA card, even if the adaptor thingy works then the USB port won't be able to cope with the demand and if for example you're transferring video footage you may end up with dropped frames.
