First attempt at water
Damn, for a first time those bends look stunning. You've done an excellent job as their are some pretty complex runs yet they all look precisely bent and straight.
Excellent job :)
I will get the tubes shorter, but not untill the rest is done. I will redo the tubes when the new gpu goes in and I know where they can go.
In the mean time I need to get the motherboard tray cover done and the cover for the 5.25" bays.
I have an idea for the motherboard tray cover that I hope will work, we will see though.
The fluid is Aurora by Mayhems but it is diluted with some pure H2O by Mayhems and some blue dye, this has made the effect a little less but hopfully it will last a little bit longer. The nice thing about this is there is a drain port at the bottom near the rad and I can change the coolant to anything I want because I can change the colour of the light box at the bottom.
will be interested to see how long the diluted Aurora lasts - could be something to use in my upcoming project if it works well.
Right, just a small update, pictures will follow later this week.
I managed to pick myself up a new GPU and power supply in the black friday deals that OCUK did.
So I now have a Sapphire Radeon R9 Nitro 390 8192MB GDDR5 PCI-Express Graphics Card with Backplate and a Corsair AX1200i Digital ATX '80 Plus Platinum' Modular Power Supply.
After a lot of searching I found a water block that fits the R9 390 so that has now been fitted to the GPU and the new PSU will be going in tomorrow.
The motherboard tray cover is all marked out and ready to be cut but I dont think it will be finished for a few days yet.
Sorry it has taken soooo long, been very busy recently.
I have added the new PSU and GPU and made a good start on the motherboard tray cover, still needs a bit of work though.
The new GPU is also water cooled.
Seeing someone take the 'plunge', you've got me jealous. I've not long completed my AIO cooled build, so perhaps when the itch grows too much I will modify it to a water cooled.
The coolant colour does compliment the rest of the build.
