CPU: A64 3000+ (754) Venice
Mobo: Gigabyte GA-K8NS
Memory: 1Gb DDR-SDRAM PC3200 (2.5,3,3,7)
I've read the 'Overclocking guide for newbies' Sticky/FAQ and have been trying to take the first few steps to overclock the rig above.
Firstly, from what I've read on the net, the nForce3 250 chipset on the mobo is supposed to lock PCI/AGP as standard. Is this correct?
Secondly, it's not clear to me how I can increment the FSB in the BIOS, as I'm given the following options in the Frequency/Voltage Control menu:
Can anyone advise please?
- CPU OverClock in MHz
200MHz ~ 455MHz Increase CPU frequency as user selected.
- AGP OverClock in MHz
66MHz ~ 100MHz Increase AGP frequency as user selected.
- K8 CPU Clock Ratio
Default Set K8 CPU Clock Ratio to CPU factory default. (Default value)
x4 800Mhz ~ x10 2000Mhz.Set K8 CPU Clock Ratio from x4 800Mhz to x10 2000Mhz.
- CPU Voltage Control
Normal Set VDDQ(AGP) voltage as AGP required. (Default value)
+5% Increase CPU voltage +5%.
+7.5% Increase CPU voltage +7.5%.
+10% Increase CPU voltage +10%.
- VDDQ (AGP) Voltage Control
+0.1v Increase VDDQ(AGP) voltage +0.1V.
+0.2v Increase VDDQ(AGP) voltage +0.2V.
+0.3v Increase VDDQ(AGP) voltage +0.3V.
- DDR voltage control
Normal Supply DDR voltage as DDR required. (Default value)
+0.1v Increase DDR voltage +0.1V.
+0.2v Increase DDR voltage +0.2V.
) is
