First attempt to overclock - help required
Some motherboards do. My DFI board is configured by default to slow the CPU fan down if the CPU temperature is below 50c and I forgot to disable it after a CMOS reset recently so the Freezer 64 Pro fan leaked onto the motherboard. The fan leaking is annoying as it's often virtually inaudible when controlled by the motherboard. :(
As for Next Sensor, you might want to give some information to the author about that problem (email him) and he'll help you fix it or even release a new version with fixes just for you. :)
