- 26 Jun 2010
- Hartlepool
Hi again, just thought ide give you all a look at my first pc build, if i can figure out how to put some pics on here
Sorry about the photo quallity as i dont have a camera so the pics are off my phone.
Fractal Design refine R2 case
Asus M4A79T Delux mobo
AMD Phenum 2 x4 955 cpu
CooliT eco
HIS Radeon 4850 icooler 1gig
4gig Corsair dominators 1600mhz
iCute 500w modular psu
pioneer DVD-RW
My case is a Fractal Design R2
Titaniun front with blue power button/eSATA/USBx2/audio jacks, with 2 more closed off vents(for quietness) at the rear that could take 140mm fans.
Side intake vents work great
2 120mm exhaust fans in push/pull config for the Eco
2 Silent intake fans.
7 White expantion slots
All fitted out
Close up of the CooliT eco
everything went in smooth as a nut and booted up first time, the only problem i seam to have is the 4gig of corsair 1600mhz dominators only want to run at 1333mhz, is this because i havent overclocked the cpu? ive ran memtest with no errors so im a bit stuck now. any advice as to what i can try next would be great. hope you like it!
now i need a good camera lol.
CooliT eco
pioneer DVD-RW
All fitted out
