First build advice. Help needed!
20 Feb 2012
Hi there! I need to replace my laptop, which is running an Intel i3 m330 @ 2.13GHz and 3 GB ram. I quite like the idea of the small form factor stuff/htpc, so I'm toying with the idea of building the following, but I've never done anything like this before...
- Seagate 500GB 3.5" SATA-III 6Gb/s Barracuda Hard Drive 7200RPM 16MB Cache- £65.00
- Antec NSK 2480 MATX Desktop Case With 380W EarthWatts PSU- £80.45
- LiteOn iHAS124 24x DVD±RW DL & RAM SATA Optical Drive - OEM Black with Nero Essentials- £14.99
- Microsoft Windows 7 Home Premium w/SP1 - Licence and media - 1 PC - OEM - DVD - 64-bit- £70.76
- Gigabyte GA-H67MA-USB3-B3 Intel H67 Socket 1155 8 Channel HD Audio mATX Motherbaord- £75.48
- Intel Pentium G620 2.6GHz Socket 1155 3MB L3 Cache Retail Boxed Processor- £46.61
- Corsair 4GB (2x2GB) DDR3 1333MHz Memory Kit Unbuffered CL9- £18.64
£371.93
- Are all of these components compatible?
- Will the 380w psu be fine for future upgrades like adding an i5 2500 cpu and an ssd?
- Will stock cooling fit in the case + be fine if I'm not overclocking?
- Do I need a graphics card for my monitor or will the pentium support output to a monitor?
-Will the difference between the speed of the pentium and my i3 be noticeable?
- If I want to save a bit more money is it possible to forego the windows 7 and use linux as a operating system at the start of the build?
This pc is going to be used for business-so sage, word etc, be on pretty much 24/7 for work and downloads and be used for internet access, multitasking and watching/ listening to whatever I download ;).
Thanks!
  1. Yes
  2. Yes, though I'm not sure of the quality of that PSU. Never skimp on a PSU
  3. Yes and yes
  4. The pentium has integrated graphics so that will be fine
  5. For that sort of work, probably not
  6. Linux may not support the programs you're using?
What about:
YOUR BASKET
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £79.98
1 x Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX) £61.99
1 x MSI H67MA-E35 Intel H67 (Socket 1155) DDR3 Micro-ATX Motherboard - (Sandybridge) **B3 REVISION** £61.99
1 x Intel Pentium G620 2.60GHz (Sandybridge) Socket LGA1155 Processor - Retail £47.99
1 x Corsair Builder Series CX 430W V2 '80 Plus' Power Supply (CMPSU-430CXUKV2) £39.98
1 x Fractal Design Core 1000 Midi Tower Case - Black £32.99
1 x Crucial Ballistix Sport 4GB (2x2GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (BL2KIT25664BA160A) £19.99
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £14.99
Total : £374.90 (includes shipping : £12.50).
Nicer case/PSU
Cheaper motherboard
Faster RAM
