First build help
23 Aug 2010
will these parts go well together?
i wont be overclocking and im thinking of getting the i7 950 instead
getting a case from somewhere else.
any advice would be nice :D
i want the antec because it is modular so itll help with cable management. might get the asus instead...
i wont be overclocking, should the arctic freezer 7 be ok ?
its going to be for general use, maybe play a game the odd time
Needs bigger screen tbh :P
Why are you pairing such a high end CPU and RAM with such a low end GPU and leetle screen? What is this PC's purpose?
want it to last for a couple of years just, dont really play games much on the computer so no need for an expensive gpu, itll just be for general use
would you consider an am3 quad core system ?
nope, i prefer intel more, been using the same pentium 4 for the past 6-7 years
i like things to be fast :) also want it to be "future proof" mobo comes with usb3 and sata 6gb also a few years down the line i can upgrade it to a i7 980x
the 240 has hdmi and it isnt that expensive wont game too much tbh, i will eventually get a SSD further down the line
but will 550W be enough to power this set up ? im getting the 950 and the Asus P6X58D-E now
