Hey guys, I'm currently building my first PC from scratch. My case has two built-in fans but my mobo only has one "SYS_FAN1" connection which is has 4 pins. Should I connect the front or the back build-in fan to the mobo? Also, the connections only have 3 pins rather than the 4 on the mobo. (The built-in fans also have a connection to connect to the PSU).
. Then burn iso to dvd, or use a program called rufus to burn to bootable usb.
