- 3 Oct 2011
Hello,
I am going to build my first ever system (and migrate from laptops to a desktop after so many years). Last time I had a desktop was when the Pentium III were brand new.
What I want out of this system is a rig that I can use for games (Crysis, Metro and similar do not interest me… I prefer games such as Civ, Sword of the Stars (1 and the upcoming 2), browsing the internet, MS Office work etc.
My guiding principle is that I want to have this system for several years to come (some changes can be made, but I am not looking to changing my GPU every year for example). For that reason, I am favouring a set up that is keeping component temperatures low.
I would also like to have a quite system, even though I plan on overclocking the CPU to circa 4.6-4.8.
Overall budget (excluding monitor/peripherals: £1000 - £1150)
Below are my choices so far:
Case: Corsair Obsidian 650D
CPU: Intel i5 2500k
CPU Cooler: Corsair Hydro H100
Motherboard: ASUS P8Z68 V-Pro
Memory: Corsair Vengeance 2 x 4GB (1600MHz)
GPU: MSI N570GTX Twin Frozr III Power Edition
Hard Drive 1: 128GB M4 Crucial
Hard Drive 2: Samsung F2 1TB
Monitor: BenQ EW2430
Power Supply:
Optical Drive:
Case Fans:
My Questions are the following:
1. For the above set up, is the 650D good, or should I opt for a Haf-X (price range for me £110 - £130)?
1.1. For the monitor specification (1920x1080), and with a life span of 5 years in mind, which GPU should I choose: the MSI N570GTX or the MSI R6970 Lightning (the latter being ~£50-£60 more expensive than the former).?
1.2. Which case offers the best airflow/cooling, if were to have 2 MSI N570s or 2 MSI R6970s installed?
2. Regarding the PSU: If were to have only an N570 or one R6970, what kind of PSU should I go for (should be fairly silent)?
2.1. If were to have either an SLI or Xfire, which PSU would you recommend?
3. What is a good Optical Drive? I am looking for an internal that can read and write on wide gamut of DVD and CD formats. I am not particularly fussy about BD. It would be nice to have if speed was 12x or so. My budget for this component is no more than £30.
4. Regarding the Memory, is the Corsair Vengeance good choice, or is there a better/faster Memory for roughly the same price (+- £10).
5. Finally, I have heard that the SSD have limited lifespans. Would the M4 last for 5 years or so?
6. Which Monitor would you recommend: the BenQ EW 2420 or BenQ EW 2430? I have heard that the 30 is not necessarily an overall improvement over the 20. Is that true? For my uses, which one should I go for?
I know I have asked a lot of questions… The lack of knowledge of the uninitiated one I guess.
7. Whether I were to go for the Haf-X or the 650D, would I need to buy any extra/better fans?
Thanks a lot in advance for all the advice!
CPU: Intel i5 2500k
Power Supply:
Optical Drive:
Case Fans:
