- 17 Nov 2011
Okay so built my first comp, everything worked fine.. however i have come to an issue when i turn it off then turn it back on the power just cuts out and it keeps trying to turn on and cuts out. i have stripped the system completely and gone over it again, have made sure everythings connected, but the weird thing is other times it turns on fine and just works... but turn it off then turn it on again and the problem happens again, it just cuts out.
I've checked each component at a time, they all work fine, id of thought if it was some serious the pc wouldnt turn on at all, but its working fine at the moment.. I've tried swapping the psu over too, same results. So i'm a little puzzled should i be worried about this? my only conclusion is that either i havnt got the bios set right or maybe the motherboard is faulty, but then why would it turn on and seem fine? so i dunno, i really could use an opinion.
components used -
BitFenix Merc Alpha Gaming Case - Black
Asus GeForce GTX 570 DirectCU II 1280MB GDDR5 PCI-Express Graphics Card
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM
OCZ Agility 3 120GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-120G)
Antec Kúhler H2O 620 CPU Watercooler
Kingston HyperX Genesis 8GB (4x2GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit (KHX1600C9D3K4/8GX)
Samsung SH-S222AL/RSMS 22x DVD±RW SATA Lightscribe ReWriter (Beige/Black/Silver) - Retail
OcUK USB Keyboard - Black
Corsair CMPSU-600GUK Gaming Series GS600 High Performance 600W Power Supply (i tried using a corsair 550w also)
components used -
