Hello
I have finished putting together the following components:
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail
MB-064-GI Gigabyte GA_945PL_S3 (Socket 775) PCI-Express DDR2 Motherboard
GeIL 1GB (2x512MB) PC5300 667MHz Value DDR2 Dual Channel Kit
Samsung SpinPoint P SP2504C 250GB SATA-II 8MB Cache - OEM
NEC ND3550 16x16 DVD±RW Dual Layer ReWriter (Silver) - OEM
Asus TA-212 Series Midi Tower (Silver) - 360W PSU
BFG 3DFuzion GeForce 7600 GT 256MB GDDR3 TV-Out/DVI (PCI-Express) - Retail
When I turn the power on it gets to the screen where it lists all of the components and then comes up with the error message "Disk boot failure, insert system disk and press enter". Also the dvd drive is not listed, just the hard drive. It doesn't eject and the led is not on. I connected the PSU to the dvd drive and an IDE cable connects the motherboard to the dvd drive.
The only other connection the motherboard manual mentions is the cd-in for audio, but there seems to be no cable to connect it unless you have to use the white 4 pin connector at the end of the power cable which doesn't reach.
Earlier when I checked the temperature of the cpu in was in the mid 70's. After reinstalling the heatsink it is now running at 20°C, it wouldn't have been damaged would it?
Please Help!
Thanks.
Please Help!
Thanks.
