First build problems :(
Ok it finally works! :D but new problem :/ when i put my vista home premium 64bit in to install, after the fist progress bar finishes the next screen is just some background with my mouse pointer. i tried installing xp pro and it installed fine, could it be my vista disk is screwed? :/
Vista takes ages to install. Just leave it and it will change screen eventually. I had the same screen for what seemed like 10mins or so.
