First Build Progress - Need some help
8 Jul 2009
Hey. I'm in the process of building my new rig, and I've come across some problems, so i need some help please.
I have the UD5 (Antec 1200), and its asking to connect the Northbridge fan to the connector, but i don't have a extra fan. Is this a optional feature?
(I will be posting here for other problems i come across, thanks a lot.)
I have the Corsair 750HX Modular, and it has two different power cables to the Motherboard. I've connected the very big one to the motherboard, but what about the 4pin one?
Read your motherboard manual. Carefully.
Connect both of those. Ideally the 8 pin cpu power cable rather than a 4 pin, but if you only have a 4 pin cable it wont matter much. Goes between the heatpipes and the back panel, near the cpu socket
