First build questions
27 Sep 2012
Will be putting together my first build this weekend and I would be grateful for advice on the following:
1 - should I do a test boot before assembling everything in the case?
2 - should I apply (or re-apply) thermal paste on my heatsink before installing or should I wait and see temps?
3 - if I have more fans than I can attach to the fan controller, am I better off attaching the remainder to the motherboard or the power supply?
1) I have never done, take your time and double check everything you will be ok. (don't forget the 4 or 8 pin for cpu power & CMOS rest)
2) What cpu cooler are using? if the paste is pre-applied then I would leave as is.
3) I attach them to the FPC to allow me to manually adjust.
I will be buying a Xigmatek Dark Knight SD-1283 Night Hawk Edition CPU Cooler.
I think my fan controller only allows 3 fans and I will have 5.
