- 1 Dec 2009
- Bedfordshire
Hi People.
I have just built my first PC and have need a bit of help.
Here's the problem: Upon start up, nothing displays on the screen, the screen is not detecting any input. I have made sure everything is plugged in correctly and all the fans are spinning, including the one of the GFX card. There are no beeps on startup and I know the speaker is working as I took out the GFX card just to test, and it beeped.
So far I have tried:
-Changing the GFX card
-Using the second PCI slot
-Changing the keyboard
-Changing the monitor
-changing the hdd to another sata connection.
Other Info:
Don't think the keyboard is getting any power as when I press caps no light come on on the keyboard.
Half of the 8 pin connector is covered by a piece of plastic that I don't think is meant to be removed.
Spec:
- Asus P6T
- Intel Core i7 920 Retail
- Nvidia 8800GTX
- 6gb Corsair XMS3 1600mhz
- Corsair HX 750w
- Samsung 1TB F3 Spinpoint
- Coolermaster HAF 922
Other Info:
Spec:
- Asus P6T
- Nvidia 8800GTX
- Corsair HX 750w
