First build!
7 May 2007
Ok so it's all arrived, just about to start setting it up, when I find out my screwdriver has a magnetic tip, is this going to be a problem? I'll post pics and stuff along the way, and no doubt be asking for help :p
i built mine with a magnetic screwdriver, just dont b daft and rub it along the back of your mobo and youll be fine, people are just very supersticious.
and good luck!
ags
just dont poke any holes in anything with that screwdriver and you will be fine, the strength of the magnet on the screwdriver would not be enough to cause any damage, just dont go sticking a huge fat off magnet to your hard drive. :)
