You can actually use SLI on non SLI mobos by using the hyperSLI software.
The real question is if the lanes run in sync, for the price of the MSI mobo I seriously doubt it fella. As stulid said it would be something to promote on the mobo if it did not hide it.
I've emailed MSI to find out. again from previous research it did suggest it would run at 8x/8x however i could be wrong on this as it was just peoples opinions and never found any solid proof.
i await MSI's response
ill post back with results so this is once and for all sorted ^^
I'd stick with the 7950 over the 670 at the moment. Over on the graphics card section the 7950s are overclocking pass a 670 oc and benching much higher on 3d mark. That's for 100 pounds less of a price. The 7950s are truly best bang for buck at the moment.
