First Custom Loop - please help
26 Aug 2009
I want to watercool GPU and i6700k, I currently have a 980ti but will probably upgrade
I have this case
http://www.lian-li.com/en/dt_portfolio/pc-o5s/
The spec says "Space for radiator"
(W)300mm
(D)130mm
(H)60mm
The vent is for a 240mm radiator, so I'm looking at this one and I should have room to attach 25mm fans from what I can tell.
I aslso plan to move the PSU down further to make some space for tubing if necessary.
https://www.overclockers.co.uk/ek-water-blocks-ek-coolstream-xe-240-double-wc-841-ek.html
Once a GPU is stripped for a waterblock I think I can fit this on the base of the case, at the back end of the GPU, not sure if I need to consider the 140 version. The 100 version is about as high as the GPU is currently.
https://www.overclockers.co.uk/ek-water-blocks-ek-xres-100-revo-d5-pwm-incl.-pump-wc-883-ek.html
here's how my case currently looks
New PC Build by dancook1982, on Flickr
Does this seem like a good selection? is there better? I'd like to buy once and make the most of it.
