First DSLR
Yeah probably the 750D, but then all the reviews read said buy the 760D instead. But your then looking at £700/£800 for the body and kit lens.
I certainly couldn't find a Canon that offered the same as the D5500 for similar money. Ended up looking at the 750D/760D and just couldn't justify the extra cost.
At lower f numbers you can have a greater depth of field, allowing the main subject of the image to be perfectly in focus, with the background nicely softened. The photographic term for it is bokeh (https://en.wikipedia.org/wiki/Bokeh).
A lower f number is a wider aperture, which lets more light in, allowing you to take photos even in lower light situations.
Just as an example, in the past with my D3200 and both the 18-55mm Kit lens, and also a Nikon 55-200mm, when shooting motorsport, the lenses struggle to even focus as soon as it becomes overcast, or towards the end of the day as it starts to get dark.
By contrast at my Niece's wedding recently, my Nikon 50mm F1.8 was able to shoot indoor shots in relative darkness during a Disco, without even using the flash.
As long as you are buying good quality branded cards like SanDisk, Lexar, Samsung etc. then failure should be fairly rare anyway.
I personally would buy several smaller cards, even say 4x 16GB cards, as 16GB still holds 300+ photos (at least on my D3200), as you then you can always have an empty card on the go (i.e. don't have to clear it between shoots, and don't have to risk losing any already shot photos e.g. if your camera is stolen with a single big card in it.)
your the wrong way round you have less depth of field not more
Cheers. I was told things like the motor lens focus motor making noises when recording movies on the 5500 compared to the 750D?
Also the speed of focus is slower on the 5500?
Whats your take on this dhill?
To be honest, I've not noticed much of a noise with the auto focusing of either lens. But then it's not something I've listened out for as it wasn't a priority when I was looking to buy as I don't intend on shooting much video. And as such wasn't something I was looking to compare on the cameras.
I have read reviews that I recall mentioning the noise of the motors when recording video, but I can't remember if it was acamera review or a lens review....I have read so many reviews since starting my search lol.
Thanks again.
Where would be the best place to buy DSLRs these days? Jessops? Or are there cheaper online alternatives? (Not grey import I hope!)
I'd be tempted to look at the 7100 over 5500
There are some advantages to each.
If your just starting out I would just get a body and kit lens.
The kit lens will take great photos and you can learn a lot with it.
These cameras are complicated enough on there own.
Best to leave extra lenses for a bit until you understand things better.
Looked at going down that path myself as well, but it all comes down to cost and value for money/ law of diminishing returns at the end of the day.
750D body only - £459 (£409 after cashback)
D5500 body only - £499
760D body only - £549 (£499 after cashback)
D7100 body only - £569
750D + 18-55mm kit lens £579 (£529 after cashback)
D5500 + 18-55mm kit lens £569
760D + 18-55mm kit lens £728 (£658 after cashback)
D7100 + 18-105mm kit lens £799
The D7200 is often coined as a "pro-sumer" camera, marking it above the D3xxx and D5xxx ranges due to a number of features, things like 100% accuracy pentaprism viewfinder, 51-point AF system, bracketing, in-body focus motor to allow use with older lenses, weather sealed, dual card slots, etc etc.
I have the D7200 with battery grip and it's absolutely fantastic. I need to grow my lens collection around it to get the most out of it.
I highly recommend anyone wanting to buy a dSLR body goes and holds them in their hands first. I hated the feel of the old Canon rebel in my hand so went for a Nikon D50 at the time. Just felt so much nicer.
You can get some blinding deals if you go second hand, too.
Bang on.
Although the 7200 doesn't haven't GPS unfortunately, but this a minor point.
How right you are. This is paramount.
I tried the 5500 and actually one of the things that put me off was the weight balance with bigger lenses, it just feels like the camera was about to tip over in my hand. The grip, although feels nice, just doesn't feel as complete to me as the D7200, hence this was one of my reasons for going for this.
Absolutely. This is really important. Everyone is different and grips vary a lot, even within brands. It's worth finding one you're comfortable with because whilst you will get used to any camera over time, if it's uncomfortable for whatever reason that will likely never change. Try with some different lenses mounted too.
It's harder to find a bricks and mortar camera store locally these days, but if you can visit one it's well worth doing, even if you end up buying online. Worth asking if they'll price match if you like the store though. My local Jessops were always very amenable to this (sadly gone now though).
